GIMP 2.8.22 erschienen
Beitragvon eleanora » Fr 12. Mai 2017, 06:22
Gestern Abend hat das GIMP-Team ein neues Update für GIMP 2.8 veröffentlicht. In der neuen Version GIMP 2.8.22 sind viele noch vorhandene Fehlerchen korrigiert worden. Es gibt aber keine neuen Funktionen darin.
Das neue GIMP erhaltet ihr auf der Download-Seite von GIMP.org --> https://www.gimp.org/downloads
Hier könnt ihr die Veröffentlichung im Original noch einmal nachlesen.
Hi,
we are releasing GIMP 2.8.22 with various bug fixes.
All platforms will benefit from a change to the image window hierarchy
in single window mode, which improves painting performance when certain
GTK+ themes are used.
This version fixes an ancient CVE bug, CVE-2007-3126. Due to this bug,
the ICO file import plug-in could be crashed by specially crafted image
files. Our attempts to reproduce the bug failed with 2.8 and thus the
impact had likely been minimal for years, but now it is gone for good.
Users on the Apple macOS platforms will benefit from fixes for crashes
during drag&drop and copy&paste operations. On the Microsoft Windows
platforms, crashes encountered when using the color picker with special
multi-screen setups are gone, and picking the actual color instead of
black from anywhere on the screen should finally be possible.
For a complete list of changes since 2.8.20 please see the "Changes"
section below. Also see the release notes of the 2.8 series at
https://www.gimp.org/release-notes/gimp-2.8.html
Happy GIMPing,
--Michael
Download
GIMP 2.8.22 is available from:
and the mirrors listed in
https://www.gimp.org/downloads/#mirrors
Please use the torrents to distribute the download bandwidth across
many mirrors. You can also help seeding the packages this way.
Direct links to the download directories are available below, these are
set up to use a random mirror:
https://download.gimp.org/mirror/pub/gimp/v2.8/
https://download.gimp.org/mirror/pub/gimp/v2.8/osx/
https://download.gimp.org/mirror/pub/gimp/v2.8/windows/
SHA1 checksums for the GIMP 2.8.22 downloads are as follows:
c894a0d9a864d418bdbd30a22d698c731583e5c4 gimp-2.8.22.tar.bz2
25c276d82da6b9bd07478f9d1d9bd4faccea9d4a gimp-2.8.22-x86_64.dmg
cf6fa10746a056ac728a83bd0121b83d645423de gimp-2.8.22-setup.exe
Overview of Changes from GIMP 2.8.20 to GIMP 2.8.22
GUI:
- improve drawing performance in single window mode, especially with
pixmap themes
macOS DMG:
- Make the launcher script also set BABL_PATH
- Add patch for GTK+ Bug 743717 to the build which concerns crashes
during clipboard operations with a clipboard manager active
- Add patch for GTK+ Bug 767091 to the build which concerns crashes
on some drag & drop operations
- generate OSX package metadata during build
Plug-ins:
- Fix for CVE-2007-3126, a bug in the ICO plug-in which allowed
context-dependent attackers to cause a denial of service (crash)
via an ICO file with an InfoHeader containing a Height of zero.
We couldn't reproduce any crash in recent version, but fixed the
error messages for good measure
- Avoid creating wrong layer group structure when importing PSD
files (already fixed in 2.8.20, didn't make it to the NEWS)
- Prevent a crash in PDF plug-in if images or resolution are large
- stop parsing invalid PCX files early and prevent a segmentation fault
General:
- if NOCONFIGURE is set, autogen.sh won't run configure
- VPATH builds for win32 targets have been fixed
Updated Translations:
- Basque
- Brazilian Portuguese
- Catalan
- Chinese (PRC)
- Finnish
- Greek
- Hungarian
- Italian
- Kazakh
- Norwegian
- Polish
- Slovenian
- Spanish
- Swedish
Contributors
Ell, Jehan, Kristian Rietveld, Marco Ciampa, Massimo Valentini,
Michael Natterer, Michael Schumacher, Tobias Stoeckmann, Éric Hoffman
Translators
Anders Jonsson, Balázs Meskó, Baurzhan Muftakhidinov,
Daniel Mustieles, Dimitris Spingos (Δημήτρης Σπίγγος), Fran Dieguez,
Inaki Larranaga Murgoitio, Jeff Bai, Jiri Grönroos, Jordi Mas,
Kjartan Maraas, Marco Ciampa, Martin Srebotnjak, Piotr Drąg,
Rafael Fontenelle
Regards,
Michael
GPG: 96A8 B38A 728A 577D 724D 60E5 F855 53EC B36D 4CDD
_______________________________________________
gimp-developer-list mailing list
List address: gimp-developer-list@gnome.org
List membership: https://mail.gnome.org/mailman/listinfo ... loper-list
List archives: https://mail.gnome.org/archives/gimp-developer-list
Re: GIMP 2.8.22 erschienen
Beitragvon Alias Grace » Mo 15. Mai 2017, 18:38
danke dir. :)
Beitragvon eibauoma » Mi 17. Mai 2017, 11:57
Die neue Version von gimp.org wollte ich ausprobieren.
Ich bin unterwegs mit Windows 10 Home (64 bit)
Trotz vorheriger kompletter Deinstallation von Gimp via Systemsteuerung, Löschen des persönlichen Gimpordners einschließlich G'mic, Mathmap und GAP meckert das Programm beim Starten mit mir rum :heul:
Der Prozedureinsprungpunkt _ZdlPvy wird nicht gefunden in den Dateien web-page.exe, help-browser.exe und file-pdf-load.exe.
Nachdem ich bei jedem Gimpstart die sechs Meldungen bestätigt habe, läuft Gimp wie am Schnürchen.
u.a. für die Spielmätze ist über Werkzeuge-GEGL-Operationen eine Vielzahl an Funktionen und Einstellungen möglich. Ich habe schön bunt mit dem Render-Filter Muster- Obist begonnen. Probierts mal aus, aber vergesst nicht, zwischendurch was Schönes zu speichern.
Zurück zu „Gimp-News“
